Obviously the 454 fills the engine bay-I assume it has a Hood, so I would first pull the Hood and see if it is air not being able to get out of the engine bay (does it overheat in traffic and/or on the Highway)?
Secondly, the Fan setup does sound a little wonky, and an electric fan may help-
I have a 540 BBC (850 hp) in my '35 Ford, and was so concerned regarding airflow that I located my A/C Condenser under my front fender (with a electric fan/shielding) and mounted my Tranny Cooler under the Car (also with an electric fan/thermostat)-
I am running a 4 tube copper radiator, and due to a tight engine compartment a 17" Spal pusher curved blade fan and louvered inner Fenders-
I also have a 160 degree Thermostat and overflow Tank-
With this configuration, it has never gone over 180 degrees (on a 105 degree day)-
Make sure your fan belt is tight-you may also have to run a cooler on your engine oil (it will help)-
