21 - 40 of 55 Posts
Discussion Starter · #21 ·
Progress is slowing as the project moves into small tedious jobs that seem to take forever
Got the engine and the mounts mocked up, along with getting the steering reconnected
617669
617670
617671
617672
617673
Discussion Starter · #22 ·
Original rear got pulled today, cleaned up the leaf springs, mocked up the 8.2 and removed two of the old crossmembers...not a lot of progress but some
617683
617684
617685
617686
Discussion Starter · #23 ·
Time for some overdue updates
Took the engine mounts to a local fab shop for final welding....
617936
Front fender got primed...it's now in paint but I didn't snap any pics
617937
617938
Engine's finally sitting on bolted mounts... truck dropped roughly 1.5inches with the engines weight on the chassis
617939
617940
Trans placement looks like it won't cause too many fitment issues
617941
Final cross member fitment will be 3" up from the bottom of the frame rail....the tail shaft angle sits 2.75 degrees downward
617942
Discussion Starter · #24 ·
Took the rear to a local 4x4 shop to have the R/P and diff installed. I've had them set up gears before and never had an issue.
617943
Limited options when it comes to diffs for the 8.2 so I ended up with the Yukon unit
617944
Axles and brakes on
617946
Followed by the diff cover.... moved the shocks to behind the rear as opposed to in front
617947
617948
Rims got some paint love
617949
Tires mounted and finally it's a roller again
617950
Rear shock pics are still in mock up...cross member will be sitting lower in the frame rail
617951
Discussion Starter · #27 ·
LOOKIN' GOOD ! ! ! ! !
Thanks!
Got the rear shocks fully mounted @ a 10degree angle but man they look really straight up in photos
618168
Spent some time putting the dash back together
618169
New chrome bezel, polished up the stainless trim and the ignition switch
618170
618171
Filled some holes and then cut some new ones
618172
618173
618174
Discussion Starter · #28 · (Edited)
So the last beetle that got put together was painted arktis... original color to the car and one year only color... debating painting the firewall arktis, bright white or sticking to all black ...:unsure:
618175
Discussion Starter · #29 ·
So... turns out I'm the grand winner in the bondo lottery.
Much like the fenders, lots of dents and an abuse of bondo to shape and flatten out the surface...
618245
618246
618247
618248
Discussion Starter · #30 ·
Made some more progress with the metal work... having a heat wave the last couple of days sort of slows things down. My headers showed up yesterday... Patriot tri 5 fenderwell headers. Needed these to clear the steering box and the motor mounts but they are a little on the crazy side
618280
618281
618282
618283
618284
618285
Discussion Starter · #33 ·
More of the same...fill some holes and drill some holes
618344
618345
Was going to run two 2 5/8 gauges offset to the left in the overhead panel... but the curvature of the panel made it impossible for the gauges to appear optically "straight". So moving the gauges into the middle of the panel alleviates that issue
618346
618347
Rod...from a Chrysler?
She's looking good.
  • Like
Reactions: 65type1
looks like a solid truck, like pugsy said, dents beat rust any day
always wanted to build a pre-war truck until i sat in one, at 6'4" my knees were on the dash hard
i laugh when i think of the waltons driving 3 in the cab, my shoulders are half the width of the cab
That's funny, but close to home. I love these old trucks, but my buddy and I tried to sit in one together. He is 6'3 about 350 and I am 6 foot and about 300. We touch in the middle and each has an arm hanging out the window. They were not made for buffet busters. I have a 47 Ford that's a little roomier.
Discussion Starter · #38 · (Edited)
Glad to see another 1940 getting a new life. You have gone further than I dared and it still took me 4 years to get it like this. Looking forward to seeing your completed project.
Thanks...your truck looks sweet. Anymore details or pics you'd care to share?
Got the first one done
618366
And then there were 2
618367
618368
And because I'm a child at heart... couldn't resist seeing what the mounted headers look like
618369
618370
618371
618372
618373
Result....awesome ridiculousness
Discussion Starter · #40 ·
Been a while since I've done any updates...so it's the good, the bad and the ugly update
Finally made a decision on what to do with the running boards... spray on bed liner makes them useable without worrying about scratches and rock chips.
Wood Road surface Bedrock Automotive exterior Automotive wheel system
Road surface Wood Asphalt Bedrock Automotive tire
Wood Plant Door Electric blue Font
Body got some paint which is the good
Hood Vehicle Automotive lighting Motor vehicle Automotive tire
Vehicle Automotive tire Motor vehicle Automotive lighting Automotive design
Tent Window Automotive lighting Hood Automotive tire
Wheel Car Automotive tire Automotive lighting Motor vehicle
Tire Wheel Motor vehicle Automotive lighting Bicycle tire
And then the bad and the ugly.... Rolled it partially outside to take a look in the sun light and didn't notice the tent door was hanging a little low... anyone interested in a project vehicle...
Vehicle Automotive parking light Car Motor vehicle Automotive lighting
Tire Automotive tire Hood Motor vehicle Automotive lighting
21 - 40 of 55 Posts
