1940 Chevy Pickup Hot Rod in the making
11928 Views 160 Replies 17 Participants Last post by  65type1
I've had mustangs (currently have two in the garage) and vintage Volkswagens that I've built and sold over the years but never pulled the trigger on a "farm truck". I grew up as a kid around the 80's and 90's street rod scene and always had an affinity for the 30's to 50's trucks but never really considered owning one; until the end of April when I finally caved in and picked up my first pre-war vehicle. It's a relatively stock 1940 Chevy pickup that was supposedly restored sometime in the 70's.
Wheel Car Tire Vehicle Motor vehicle
Ended up driving the truck home that day but took a bypass that avoided the mountain road.
617078
Took the better part of the day but the truck made it home. Initial findings, brakes worked great, original 216ci straight six smoked or leaked enough oil to rival the exxon valdez, 3spd bull nose trans was an experience and the wiring was sketchy as hell.... but it started, steered and stopped all the way home.
617079
61 - 80 of 161 Posts
· Registered
1964 Thunderbird, 390 FE
· Registered
1940 Chevy Pickup/ 2007 GT500
Discussion Starter · #62 ·
lol... Couple of weeks ago went for a cruise with a buddy...first thing he said when he got out of his car, you look like a dumb ass wearing that Toyota hat while driving a Ford.
What can I say, I love my Tacoma 😁
· Registered
Discussion Starter · #64 ·
Summit box showed up today..so some joy followed by slight sorrow. When I estimated measurements for my Hilborn style scoop I was mostly focused on height and I forgot about depth...damn thing won't fit without hacking up the firewall...sigh
Motor vehicle Automotive tire Tire Hood Automotive lighting
Vehicle Automotive tire Hood Motor vehicle Automotive design
Motor vehicle Automotive tire Automotive design Rim Bumper
Tire Car Wheel Vehicle Automotive tire
Motor vehicle Automotive design Hood Automotive exterior Gas
Motor vehicle Automotive tire Automotive lighting Hood Automotive design
Motor vehicle Hood Automotive design Automotive tire Automotive exterior
Tire Wheel Plant Vehicle Automotive tire
Car Land vehicle Vehicle Grille Automotive lighting
Motor vehicle Automotive design Hood Automotive tire Engineering
· Registered
Discussion Starter · #67 ·
Couple more fail points and then some interesting and positive developments
Rear brake lines designed to fit 68-72 Chevelle...fell a little short. My ARP bolts are fine thread and the balancer on my BBC is course threaded...fail
Followed by some good news... when I mocked the driveline up the first time we ended up raising the trans 2.5" to get an approximate drive line angle. When the truck went back together this last time the angles and the numbers seamed out of wack so I ditched the 2.5" riser block.
Today I put the blocks back in the trans mount and viola.... all my little fitment issues went away. Steering column clears, the recess for the passenger side valve cover slides in and out easily, room to get at the distributor.
With enough room for my scoop to fit with some minor trimming of the rear carb mount... Win!
Automotive lighting Automotive tire Gas Automotive exterior Motor vehicle
Motor vehicle Yellow Automotive lighting Font Gas
Hood Automotive tire Motor vehicle Vehicle Automotive lighting
Tire Car Automotive lighting Automotive tire Motor vehicle
Land vehicle Motor vehicle Vehicle Automotive tire Bumper
· the 'Duracell Project'
if you like the look, i'd modify the scoop in a heartbeat
that highrise manifold looks good now, anyone know of a clearcoat that you can spray on it to keep the look?
my ramjet intake looked good for a couple years, not so much now
· Rod...from a Chrysler?
Ya, aluminum is a PITA. That's why I powder coated my TPI. Looked good for a long time. The fuel rails, not so long.
Gas Cylinder Motor vehicle Electronic device Auto part
· Registered
Discussion Starter · #71 ·
Little bit of this and a little bit of that going on...
Spent way to long modifying the electrical wiper motor arms to fit the truck... actually just the first one took a lot of measuring and trial/error to get the right length time.
Gas Composite material Tool Road surface Asphalt
Automotive tire Rim Idiophone Composite material Tire
Started to put some of the interior bits in place... rear cab backing
Automotive parking light Motor vehicle Automotive lighting Hood Automotive design
Mounted the grill and started the hood lace
Tire Wheel Grille Vehicle Automotive lighting
Car Grille Vehicle Automotive tire Automotive lighting
Automotive lighting Hood Automotive tire Motor vehicle Automotive design
· Registered
Discussion Starter · #72 ·
Fitted some more of the interior bits, gauge bezel's will need to be painted black so they blend into the background a little better.
Current struggle is getting the new rear window rubber around the glass and into the frame. Ended up taping the rubber to the external frame in an attempt to get the twist out of the new rubber...will see if it works
Automotive lighting Hood Motor vehicle Lighting Automotive design
Automotive parking light Motor vehicle Automotive lighting Hood Automotive tire
· Registered
Discussion Starter · #73 ·
Progress is slowing due to a string of parts arriving that aren't the right part or the right part arrives "according to the manufacturer" and then simply doesn't fit.. and making the parts either from scratch or modifying to fit is slow and annoying at the least
Car Tire Wheel Vehicle Motor vehicle
Automotive lighting Automotive tire Hood Tire Vehicle
Motor vehicle Car Automotive design Hood Vehicle door
Wheel Tire Car Vehicle Automotive tire
Wheel Tire Land vehicle Car Vehicle
· Registered
Discussion Starter · #74 ·
Some minor updates.. most of which can't be shown. Updated the carbs to 50cc accelerator pumps and added dual quick change covers for the vacuum secondaries. Changed out the thermostat housing for a straight unit.
Rear brake lines installed, used the TItan tool for flaring the lines...highly recommend it.
Connected and ran the choke and hand throttle cables through the firewall, just need to cut them for length. Nice part about having dual carbs with manual chokes is I can utilize the original dash controls.
Automotive tire Motor vehicle Automotive design Automotive exterior Engineering
Automotive tire Bumper Automotive exterior Motor vehicle Automotive design
Automotive tire Motor vehicle Bicycle tire Vehicle brake Bicycle part
Wheel Tire Hood Automotive tire Motor vehicle
Gesture Font Material property Tie Flooring
· Registered
Discussion Starter · #76 · (Edited)
Took some time off as winter hit, but I've slowly started back at it. Working on the fuel lines the last couple of days... decided to make life more difficult and use a combination of 3/8 stainless lines with -an fittings.
Using a Rigid 37 Degree flaring tool for stainless and a Jegs tubing bender. Thankfully I don't have a lot of line to run as I find stainless is a pain to bend.
Also got some parts back from the plater... mounted the top hat and that's about it for now.
Motor vehicle Hood Automotive design Automotive exterior Automotive tire
Motor vehicle Automotive exterior Gas Auto part Engineering
Tire Vehicle Automotive tire Motor vehicle Hood
Motor vehicle Automotive design Auto part Automotive exterior Gas
Car Vehicle Hood Motor vehicle Automotive design
· Registered
Nice looking truck. I have one of those Titan type pipe flaring tool and like you I would highly recommend them as well. Best tool I have found for the amateur . Nice thing you can use them to flare pipes even when stuck under the car/truck.
· More for Less Racer
A couple bits of info on the Tunnel Ram you may not know.
Vacuum secondary carbs require that the vacuum pods be connected, so that both secondary's open synchronized to each other. You don't want one wide open and one only half open.
Holley sells lids with a hose nipple, but they are rather expensive.
Allstate Carburation has them for about 1/2 of Holleys price.
HOLLEY VACUUM SECONDARY WITH BALANCE TUBES - Allstate Carburetor (allcarbs.com)
Allstate is a great source of parts.
You may find it easier and better to just drill and tap the center of your Quick Change lids to add a small hose nipple to each lid.
There was someone making the Holley lower housing with a hose nipple, passage intersects on the side close to the vacuum passage feed into the main body instead of putting it up on the lid, and I've read a link on how to add it there yourself.....I'll see if I can find it if you think you want to go that way for a more hidden hose install so it looks cleaner.
i think it was at the Race Fuel Systems forum somewhere.
racingfuelsystems - Racing Fuel Systems (tapatalk.com)
You're also likely to need lighter rate springs, which looks like you already know since you bought the quickchange lids.
i would guess either Long Yellow or Short Yellow.....maybe Purple and possibly even White.
The stock Plain(Silver) is too stiff, even in stock single 4 barrel form it won't be fully open until 5000+ rpm.....and you've got signal split between two carbs!!
Great looking Chevy, by the way!!!
· Registered
Discussion Starter · #80 ·
Thanks for the taking the time to share your knowledge, much appreciated.
I do have the spring kit and the quick change lids with nipples. The nipples are there but don't really show up in the pics... connecting them is on my to do list.
