1 - 10 of 10 Posts
Hi i am new to this site and have a 49 F1 and want to install power steering and have heard the Toyota gear box works well, also want to lower the truck any suggestions and info?? I already own a Toyota 4x4 for the donor gear box and am using the stock F1 frame.. thanks
I have a '50 F47 (Canadian F1) that I hope to start 1 day. I plan on dropping the front axle, and using an Explorer rear with the springs mounted below. You can do the same with the front axle but you might run into clearance problems. I've got the steering box and the rear end, but that's as far as I have gone.
What kind of clearance problems do you think I will run into? Want to go with about a 3 inch drop axle and the Toyota steering with a total disc brake conversion!!
Discussion Starter · #8 ·
I heard that too!! Do you know what year explorer axles work for this?? I am guessing the smaller older explorers like 03 and older, not sure the year they went with the bigger body!! Thanks alot for the info!!!
For disc brakes you'll need a 96 or newer Explorer rear. Bear in mind I haven't put it in yet, but I know there'll be some cutting and welding involved to make it fit. It's not a bolt in. Here's a good article from Ford Truck enthusiasts that's good reading. About 1/2 way down there's info on Explorer rear ends.
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
1 - 10 of 10 Posts
