Many beads to roll on my cheap HF bead roller and couldn't have done it without my assistant (and wife of 34 years). This ain't her first rodeo either! She's helped me pull many a motor and trans over the years!
All buttoned up.....
On to the pass side.
This side was more extensive so I decided to pull the door for easier access. Built a door dolly out of 2x4s and some cheap casters I had laying around. Made it real easy to pull the door myself (didn't even need the wife to help) and it's mobile so very easy to roll around.
Cut out the offending cancer.....
Same issues with the right side body brace and inner rocker.....
Done....
Right side toeboard....
Had to replace the right rear floorpan also.......
Had to make the small 'under the seat' section outta 5-6 pieces because of the elevations....
I think it all came out pretty good considering it was done on the cheap!
While I was at it I noticed rust starting to come through the previous owners bodywork on the pass side rocker panel. I ground the old bondo out and found this mess....
Cleaned, derusted, POR15'd and welded in a new panel. A fresh coat of mud should get it looking just fine.
Next up is lay down some seam sealer and primer then I'll probably jump on the front suspension. More to come!
Done....
