I am getting down to the point where I will be buying parts soon.
I have a couple of questions that I need some help with in regarding building this engine.
Stock 327 torn down but in excellent condition. I plan to bore .030 over minimum as condition requires.
My engine comes with a brand new stock dimension forged crank.
Edelbrock brand new edl-2201 rolling thunder cam
Edelbrock 2201 Edelbrock Rollin' Thunder Hydraulic Roller Camshafts & Kits - Free Shipping on All Orders @ JEGS - Free Shipping on All Orders @ JEGS
And a Edelbrock 7101 performer RPM intake Manifold , lightly used.
http://www.summitracing.com/parts/EDL-7101/
1-5/8 diameter headers. MSD ignitions. ( looking for favorites on these)
Howard lifters
http://www.summitracing.com/parts/hrs-91164n
Is there an advantage, that is worth the additional cost, to buy forged pistons instead of Hypereutectic? Flat tops with two valve reliefs.
Speed-Pro L2165F30-8 : Speed-Pro Power Forged Pistons - Set of 8 - Flat Top - 4.030" Bore - Chevy - 327 $365
Sealed Power Hypereutectic Flat Top 2 Valve Reliefs Piston | Northern Auto Parts about $200
Can I use the existing 1962 327 connecting rods with either one of these pistons? ( Condition is great)
I am planning to buy the Pro-filer heads set up with springs for hydraulic roller cam with a lift of .550 will this work?
SBC 23 Degree Cylinder Head, 11/32 Guides & Steel Seats
Intake Port Size: 180cc Intake Ports
Chamber Size: 64cc As Cast Chamber
Spark Plug Orientation: Straight Plug
Intake Valves: 2.02/1.600 Valve Job
Spring Package: Standard .650 Lift 1.525 Dual Springs, Steel Retainers, Keepers Assembled
Casting Style: Standard Cooling
Item Number: 176 $1090 a set.
Please let me know what rod I should be getting and rockers.
My husband likes the Pro-comp heads ( price and reputation of old )but I have heard mixed reviews mostly based on country of origin and quality from one set to the next. Most common I have seen are 64cc with 185cc intake runners.
Which flow better? The Profilers or the Pro-comps? I have heard all heads out of the box need to be torn down and cleaned up, is this true?
And last but least, recommended rebuild kit ( gaskets, etc) to go with these setups and to get the appropriate squish of .040
Also Carb preferences?
I had a similar post back in April. As I said narrowing down the choices.
Thank you for your time.:welcome:
Lori-Anne
Howard lifters
Lori-Anne
