I have a 1967 c10 I just installed a 383 stroker. Now it won't go into any gear. It has fluid, vacuum, looks to be bolted on right. Any ideas will help a lot.
when you install the converter you need to feel 2 drops (as my dad would say)
install it and rotate it until is goes in again to catch the pump ears. Also there should about a 3/16 to a 1/4 gap between the flexplate and converter bolts. Usually I stack or shim the gap with 2 flat washers for each hole when i bolt it up to the flex plate. if you pulled the converter all the way forward you might have disengaged it from the front pump.
I actually shimmed it yesterday and put a bit more transmission fluid. It went in to gear finally. Thanks everyone.
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
