I'm in the process of changing over from 4 wheel drum to disk brakes up front and the stock drums in the rear.
I'm at the point of trying to get the Adjustable Proportioning Valve installed in to the rear brake line. The rear line that is there right now is 1/4 inch. The brake kit came with some 3/16th inch line.
Would it be ok to run the 3/16th inch line from the metering block (I believe that is what it is called) to the proportioning valve. Then have 1/4 inch line coming from the valve to the rear drums?
Thank you.
p.s. any hints / tips on making double flare ends would be greatly appreciated.
Thank you.
