1 - 7 of 7 Posts
I have recently purchased a 68 Charger and the exterior is mint. I have 2 new Charger badges to put on the rear pillars but are unsure of exactly where to put them. It has a black vinal roof and the badges have 2 small pins to assist with the fastening of the badges. Is it best to cut them off and just use a adheasive or do I drill holes as well as glueing them. I want to make sure that I get this right. Is there anyone out there that might be able to offer a suggestion or 2 of exact location and best method of fastening.
Thanks,
Dion.
Many older cars, emblems were held on by nuts or speed nuts. A speed nut could be meant to thread on those pins. Or they could be just an alignment aid to put the emblem on straight and the emblem glued or 3m two sided taped on (not very likely in 1968 that this was used, don't believe it was around then) Is it possible it had two holes for the pin to go through that got covered with body filler or with something at some point. You could break the pins off and glue it on or two sided tape it on. You will just have to eye it and put it on straight. Make sure both the back of the emblem and the vinyl are cleaned, wipe with some wax and grease remover maybe. I am not sure how well the two sided tape will stick to vinyl, as I've never tried it, but it does stick to most things well if they are clean. You will want something that will stick well to the vinyl. You could also try plastic emblem adhesive, or even epoxy or windshield urethane, but with something like that you have to be carefull so you don't apply too much that it oozes out from behing the emblem and makes a mess. be ready with a rag and solvent to clean up an excess right away. My guess is that this was speed nutted on and accessed by removing interior panel from the factory, but don't take my word on it, cause haven't owned or worked on that car. Here is a picture of a 68 from google image search.
RE : Badges
When I had a new top installed on my gallaxie , I had the same problem.
I peeled back the roof liner opposite the mounting area on the inside of the car ,so that you can see the 2 holes, then , while supporting the outside vinyl with one hand , I used a scriber to punch through the vinyl , pressed in
the badges ,pushed on the retainer bushings , refit the liner , all was good...
:thumbup:
I just looked at some pics of a 68 Charger I did 2 decades ago, looks like there's holes there. So, yea, might find them under the headliner as was said. If not, might try asking on Moparts forum, usually hundreds of Mopar guys on there at all times. Fun car, good luck! :thumbup:
I believe those are held on with barrel clips. They would fit into the holes, the emblem is then pushed into the clips. If the pins are tapered, speed nuts, if they aren'e tapered, probably barrel clips. With a car like this, I'd try to do this the proper way. :thumbup: Dan
1 - 7 of 7 Posts
