381 - 400 of 422 Posts
Rod...from a Chrysler?
Discussion Starter #381
  • Like
Reactions: idrivejunk
Discussion Starter #382
The post above is because of major frustration with the project.
Anyhow, a couple of patches were required to finish the gaps on passenger door.
Now you see the holes..............
527192
527193
527194
527195
And now................you still see them............
527196
527197
Discussion Starter #383
All glass removed.
I added a 3/4" x 3/16" cold rolled bar under the door skin with threaded holes for the rear view. I don't know about you fellas, but I've cringed my whole life whenever I've had a Chevy with a loose mirror. Nice solid mount, sweet, never worry about stripped out sheet metal again.
Rear view moved forward about 6".
527198
527200
527199
Discussion Starter #384
Installed the door to check out the patch....hmm....not so good. I screwed up royally.
527201
A bit more touch up with the rod.....
527202
Back is acceptable:
527203
Discussion Starter #385
Then, around to the driver's door:
527204
A few studs to aid in pulling:
527205
Got it to an acceptable range for this particular quickie paint job. Sure better than the 3/8" that was there before.
527206
Spent some time gapping the door:
527207
527208
And then............damn............being the moron that I am, all the time working on the door, I didn't take a peak at the back of it. Dented to heck and the top section of inner shell was pulled right out of the seam.
So, a little disassembly to strike a few blows.
527209
Discussion Starter #386
Dents and door frame bent out of whack. No wonder there was so much wind noise.
The whole frame was too far forward and twisted.
527210
527211
527212
So much for my nice gaps..........
527213
Discussion Starter #387
Between waiting for Saturday to arrive to pick up the new door skin and when I discovered this mess, I needed something to do so I grabbed the gate off the car to finish stripping around the edges. I found some bondo on the bottom and decided that since I've never seen rust on hole, I would create some nice large drain holes and leave it at that. Double metal into the triple pinch weld repair was just not gonna happen at this time. I welde the two panels together at a few locations so I could weld stiffening bars on in case someone actually uses this car like a truck in the future. 99% that that will never happen.
527214
527215
527216
Discussion Starter #388
Heating and beating and welding........
527217
527218
527219
527220
527221
527222
A good sign: ???
527223
The offsets at bottom seem to line up not bad. Top left corner needs work and I will have to weld the mirror holes closed.
527224
Discussion Starter #389 (Edited)
I will move the whole inner door back so that the window frame is centered more in the opening when I assemble to the skin.
Skin will be installed about an 1/8" forward.
Will deal with the twisted door frame when assembling also.
527225
Looks better here but the door is in a twisted state to be correct. Bottom rear corner is sticking out a bit.
527226
Collector of "someday" cars
DAMN, that door was mangled good... :(
The tag on the skin is the same one on all the repro stuff. It will still look better than the bent up pos that was on there. Once again, a vehicle that looked pretty darn good had a poop load of hidden damage and p!$$ poor workmanship under the paint.
Discussion Starter #391
No kidding.
Owner couldn't drive and repair dude couldn't fix....ha....
The AMD panels I'm putting on my Camaro come from Taiwan/China too. They are some of the best fitting. It's all in the quality control over the production that makes the difference.
Discussion Starter #394
I ordered a small bottle of 1969 code 52 Garnet Red touch up paint. One of our customers was nice enough to have his painter spray out a couple of samples for me. The paint was flat so I sanded one with 1000 and used a rattle can clear on it. Amazing difference in color by adding the clear coat. These pics are a pretty good representation of the color.
I showed my daughter, all the while going off on how I loved it. She was too polite to say anything negative, but man could I see the disappointment in her face. I'm and *** as I derived some temporary pleasure from this, knowing I wouldn't use the color after reading her reaction, but let her think so for a few minutes.
527335
527336
527337
Gonna go with Victory Red. It's a nice solid darker shade of red that should go nicely with the black hood stripes.
527338
Appears to be a wee bit darker than the red on this car, which looks pretty good but just a tad too light.
527339
Discussion Starter #395
I welded what I believed to be the last patch (again) on this project, ya, right.....
527341
And of course, then there's this that I had forgotten about:
527342
All in all, the mangled up door came out not bad.
527343
527344
527345
A little bit of grunt to bring the skin in to the window frame for welding.
527346
Discussion Starter #396
Fender is just not right.
527347
I'm afraid to continue cleaning up anymore edges on the car to prepare for primer.
527348
One more patch coming up. This will allow some shape correction at the same time.
527349
Wow, looking great. That fender is stretched at the door from the crushing it got. Sucks to have to keep doing gap corrections from crash damage and previous p!$$ poor workmanship, but you are there now, so git-r-done.
The Victory Red is a deeper color and more easily procured from 2000's GM vehicles.
You are doing some great things Pugsy. We know the truck was painted by a body shop in Cincinnati. I sure would like to see a picture of it when they got it.
John
John
I doubt they would want anyone to see the butchery. The pic would need to be on a wall of shame, for all the crap he has found under the paint.
Discussion Starter #400
I added a piece of 1/8" diameter rod to the edge because welding the two pieces together directly would have came out to a sharp point.
613718
613719
Stick it on the car for a look. Damn, door gap is way off. Add some material there to close off......
613720
This don't line up, not even close. Cut along line, flatten out the fold below it and create new fold by welding the bit back on.
613721
613722
And a piece of 11 ga steel.........
613723
Looks like things are coming together....ha....ah..yuh....
613724
613725
