1 - 2 of 2 Posts
Need help please. installing an American Autowire classic upgrade harness. Purchased a replacement wiper motor from NPD. Motor has a plastic 4 position wire connector. Original motor had a rubber 4 position connector that matches the new harness I purchased. Decided to cut the old rubber connector and replace the new plastic connector so it would be a plug and play situation. Soldered red to red, white to white. figured there was no way that would be wrong. Then the black wire I mated to green , which left only one wire, which I believe was blue at the motor and I cant remember what it was on the American Auto wire plug. Is this correct?
Wiper motor
This is off the top of my head but may help with your problem. The motor will require TWO power sources coming in. One is for the regular operation and one is for the "park" mode which will run the motor after regular power is cut until it gets to a certain point (park) and then breaks the circuit. Of course the motor will require a ground also.
1 - 2 of 2 Posts
