I just picked up a 1971 Pontiac T37 a couple weeks ago that is a solid 36,000 mile car. I just got into the garage and pulled off all the front sheet metal along with the engine and trans. It is a 350ci 2 barrel, AC car with TH350 trans. Both the motor and the trans had their share of leaks so I plan on doing a gasket kit on the engine.
Here is where I would like some input. I plan doing the B&M rebuild with shift kit on the trans along with a Fairbanks stall converter I have( I will have to check the stall and post it). I don't want to dump a ton of money into the motor but would like to get some power out of it. It has the stock 94 heads which I think are the limiting factor but I still want to do a cam and lifter setup with an Edelbrock intake and long tube headers. What do you guys think? Any cam or torque converter recommendations? I'm trying to keep this project budget so I have a toy next summer to tide me over until I get my Firebird on the road. I would rather not disassemble the long block seeing how everything appears do be in good shape.
