alright so i got a 1976 k10 an when i drive it i always needs to correct it an its real loose kinda sketchy around sharp corners
Im runnin about 16 total inchs of lift if tbats a factor
Lift can add to bumpsteer pretty bad,but you may have a sloopy joint or two?
Also box may need adjusting,is very much a must to do any adjusting of box only when it is at dead center or left to right of the box/not the tires,after with the box at deadcenter,then adjust the tierods to get tires strait ahead/be sure tierod on both sides end up very close to same size/not one longer.:nono:
