Gents,
I have seen that people in the past have had the same problem. I have replaced a skanky leaky SBC305 for a stroked SBC 383.
When I was installing the motor last May, I noticed that the motor mounts were not lining up (clamshell with polyurethane mounts).
After reading threads in different forums (incomplete stories that are never followed up, you guys know that feeling), decided to proceed, partially slot the existing frame holes to get to line up the motor.
I have been successful, got to install the remaining components of the car.
Little did I know of the following:
1) Having the engine 3/4 high throws off the drive line angles.
2) I put engine into drive and there’s a mechanical noise (one clunk).
3) I’m not sure if I will be able to compensate for the change of angle out of transmission. I will shim the transmission and try to reduce the angle diffferwnce between transmission-driveshaft and driveshaft-rearend. (I have double adjustables).
This is my horror story, I will continue and see if I can overcome these fitup issues.
Now that being said, if I hit a dead end, can anyone tell why in the bloody hell the f*ck f*ck clamshell motor mounts are not lining up? Is there a discernible part number for the left and right motor mount? Believe me, I have done some researching but there is no clarification.
I appreciate all the help gentlemen. Go Chevy!!!!!
