The problem with center bolt cover heads is first I’m going to assume these are Swirl Port heads from 87 through 95. They use a slightly modified standard intake bolt pattern with the bolts along the plenum. Pre-1987 all the intake bolts are 90 degrees with the head’s machined intake surface. Starting in 87 going through 95 the bolt pair adjacent to the intake’s plenum were changed to an angle of incidence to the head’s machined intake surface to 72 degrees. The problem this will cause is the 1984 intake will not bolt up to 87-95 heads even though looking at them it’s the same bolt count in the same bolt to bolt locations. Given this is where the exhaust heat crossover is this is a highly stressed area that needs to be securely fastened.
This can be worked by clever people by egging the center holes of the intake manifold and milling/gringing a new flat surface for the bolt head to register against. There used to be an angle washer kit for this, but it’s been a long time since I hunted for any. Or plugging the screw holes in the head with a bolt shank that is held in with superglue, Lock-Tite, or epoxy then drilling and tapping new holes at the needed angle into the head. Of buying a new 4bbl intake from ProComp or Professional Products that have an adapter that will fit the 55-86 or when flipped over the 87-95 bolt angle.
The other problem is the 87-95 heads have no pushrod guidance, these heads use self guiding rockers, which is a simple, for once, substitution with a set of 87-2002 Gen I or Gen II SBC rockers.
The exhaust side is typical 7 bolt Gen I/II SBC as are the front accessory mounts.
You can see if this was going to be a money saving head swap it ain’t.
Just a note, the L30 and L31 (305/350) Vortec of 1996-2002 production use a way different Fordish SBF pattern of four bolts per side straight down.
