hey guys I have a 1986 350 small block that is hooked up to my m21 muncie
I believe it is a one piece rear main seal; I have a centerforce dual friction clutch and new flywheel on the 355 engine. i dont know the exact size of the flywheel currently on the car.
I am going to replace the 355 with a zz383 crate motor that comes with an automatic tranny flywheel and flexplate new from GM.
here is the link to the crate engine.
Chevrolet Performance 12498772 Chevrolet Performance 383ci/425HP ZZ383 Engine
I know i cant use the flywheel that comes with the crate engine. (for an automatic) Will I be able to just to take off my old flywheel from the 355 and put it on the zz383?
I will also just use my regular GM HEI distributor and Hooker headers that I had on the 355. i am also going to reuse my old edelbrock water pump on the new 383.
Is there anything I'm missing. i dont know if i would need a special flywheel for the new zz838; and i want to be sure i can reuse my old 350 edelbrock waterpump. my old starter?
any other special tips/tricks when installing the GM zz383
Thanks for you help.
