I was wondering if anybody could tell me where the thermostatic vacuum switch is on a this 1989 chevy astro van it is a 4.3l TBI I probed the conector and am getting code 32 egr solenoid checks out egr valve also able to push on egr valve any ideas would be helpful thanks.
likes chevy trucks & boobies
one in the therm housing, and another in the intake near the therm housing
cant miss them, vacuum hoses connect to them...
Its been a long time but if you have a code 32 I don't think you use a TVS for EGR. The computer pulses the vacuum via the EGR solenoid. When the coolant get hot enough maybe 100 degrees the computer controls the system. If I remember correctly the computer will test the system behind the seen by opening the EGR valve at a time you the driver would most likely not notice it, I think at freeway speed and at the same time look at the O2 sensor voltage output looking for a change to verify in a round about way the valve is working. Hope this helps, the EGR solenoid is electric but it can't remember where it is but I think its on the passenger side of the intake manifold.
John
