1 - 2 of 2 Posts
My son in law are working on getting a used 93 sonoma back on the road. The previous owners had a problem with the fuel pump causing the fuse to blow,,turns out to have been a shorted wire on the frame,(ecm and fuel pump same fuse) so the tore the wiring harness 3 ways from Sunday . we have all of it fixed and truck is running just fine but I can't get under the dash without removing my head so i cant tell where the fuse panel mounted from the factory..
this truck did not have it mounted where you open the door and pop off the plastic cover in the side of the dash and it is currently hanging under the dash left of the column need to to remount the panel pics would help :welcome:
1 - 2 of 2 Posts
