Hello,
I have a 1994 Dodge Dakota 4x4 with an Automatic Transmission that will not shift into 2nd gear until the tach is redlined at 5000 rpm. Then when it finally does shift into 2nd it jumps into 3rd,4th,and sometimes right into 5th gear. It doesn't overheat and the fluid is still that redish color and doesn't smell burnt. I've tried adjusting the Detent cable, adjusted the shift linkage and still the same result. There is no Vacuum Modulator and the shift timing is controlled by the computer. Someone mentioned that it might possible be the Governor valve in the tail housing. But I never heard of such a valve. Before I tear the thing open that far I hope someone here can explain what my problem might be and direct me towards a remedy. Any ideas? or do I need to disassemble this thing?
Thanks
Thanks
