1 - 20 of 95 Posts
Hi guys, we pulled out the engine on the 1996 Yukon.
L31 Vortec SBC, We were doing the top end only but we decided
to go with a full rebuild. We already have some parts for it.
1 - 0912 AFR Heads
2 - LT4 Hotcam
3 - 1.6 Crane Cams Gold Race roller rockers
4 - 3600 Yank Torque Converter.
We already have 1 5/8 headers and other goodies
as the Taylor intake spacer. We want to make the truck
fun to drive, not looking to make it a race truck but closer
to the feel of it.
We are going .30 over, so it will be a 355 but here's the doubt.
Which kind of pistons to run? We are going with Hypereutectic
i rebuild my 87 Vette L98 eight years ago with great success using
Mahle Flat tops and runs really great so i want to repeat the formula.
But i'd rather ask than make a mistake, we still have the black box
and no 411pcm so we might purchase a custom tuned black box for now
and later maybe a fast system so we won't have to worry about tuning
issues.
Will .030 over Mahle Flat top pistons work on my build?
or should i go with the stock dished pistons that they sell specifically
for 1996-2002 Vortec engines?
Thanks in advance.
Wrench Turner
The LT4 hot cam will like the added compression of the flat tops.With factory dish pistons, your lower rpm power can be a little a little soft with that cam.It works best with at least 10:1, or,10.5:1.
Wrench Turner
Make certain they have a 1.56" pin hgt.Some aftermarket pistons for rebuilds will have a shorter pin hgt causing the piston to sit lower in the bore.This will lower your compression & cause problems with detonation. It will be impossible to get the quench to proper range of .035 to .045 without having the block cut.
Wrench Turner
Im a big fan of the flat top pistons in the sbc they work great for many applications. If you plan or running 92 octane gas it should be fine.
Are you running the lt4 hot cam that has .525 lift or the low lift version. I like the larger one and its often the only one most people see. I think the smaller one is basically for class racing and to fit low lift heads. Its under 500 lift so its not a good choice for larger heads.
The heads certainly look like a good match for that cam with there big cfm right at .500 and .525.
This cam will need a tuned ecu or different setup.
You could use this system with a nice big carb style manifold and make the most of the setup. Most of the gm manifolds are tightly configured for flow in the range the engines can they build use. These can work with the small victor or other high flow intake.
FiTech Fuel Injection
This engine sounds like a solid build and should be well matched. I think the flat tops will make it produce the best power and the most low end torque and snap out of the motor.
Hope this helps.
There is no smaller LT4 Hot cam.The .525"lift is with 1.6 rockers, which is what comes with the Hot cam kit.It was designed as a replacement cam for showroom stock racing for LT1/LT4 engines which came with 1.6's.Using 1.5's will give you approx .495.
Discussion Starter #6
Is the 1.56" pin height something i see on specs?
Thanks!
Hope this helps.
Yes we will need a tune.
Right now we will slap the terrible stock intake with the spider
(which we already upgraded and added a manifold spacer as well ) it might run good for now but i know we are leaving lots of potential power on the table, so thanksfor the link, we are thinking about those selftuning setups for the future if there is enough proof that we will pick some considerable power
to make the investment. Hotcam with those AFR Vortec heads and 1.6 will make it nice im sure, i have a similar build on my Vette using AFR195 heads with the Lingenfelter 219 cam all together packed into a 3200 Vigilante and i really love it.
Wrench Turner
The pin hgt should be listed in the specs.It may be listed as "compression hgt".This is the measurement from piston crown to the center of the wristpin.It determines the depth the piston will sit in the bore.Some replacement pistons will sit farther down by as much as .020".They are often referred to as "rebuilders pistons".
Wrench Turner
With aluminum heads, it's not good to use thinner style shim gaskets, so, you may need to have the block cut in order to obtain a good quench distance & still be able use a good gasket suitable for aluminum heads.IMO, I wouldn't go any thinner than a .028" gasket.
Discussion Starter #9
For that heavy vehicle, you may want a piston with a D-dish cc size halfway between full dish and flat tops to prevent overheating/pinging... also, be aware the Hot Cam doesn't start pulling hard till 2,000 RPMs or so...
Wrench Turner
A D cup piston has the benefits of a flat top, but, adds some volume to help lower compression. You'll be fine with the flat tops & your head/cam choice.D cups won't be needed.That cam can be really soft down low with less than 10:1.
Discussion Starter #13
Thanks hcompton, yes i saw the forged option as well
but ...if we are going that route we would use forged rods
and crank but we won't be using any forced induction on it.
Im leaned towards hypereutectics since they work real good
on my L98 it's just that i want to follow my proven formula
but i want to make sure if those pistons will work on the L31
setup we are doing now.
Wrench Turner
Speed Pro #H631CP is also a good piston for your build if the Mahle's your looking at don't come thru.Just stay away from Speed Pro H345's.The H631 is about the same price as the Mahles at $160 per set.
Wrench Turner
Yeah,i would make sure because the only flat top Mahle's in hyper I see are #MAH2243547WR.They show a pin hgt of 1.56",but,then show compression with 64cc heads at 9.4:1. A 4.030 bore flat top with 64cc heads should put you just over 10:1.
Discussion Starter #17
so they are shorter?
is 10:1 good? i cannot remember the stock CR
but anything better is good to me, sorry for the basic questions
i've never took the time to learn much about CR and block height :confused:
The 350's are pretty simple and hyper pistons work fine. The ones i suggested were the only ones i know of that come in the 1.575 pin height. Im sure others do as well.
Has your block already been bored. It should be bored with the piston in hand. Also the bores should be finished for the type of rings to be used. Thin low tension ring need a different bore than old school thick cast rings. So if the block has been bored for modern style thin ring package you need a piston with that same ring package. Older pistons with thick cast rings will not seat properly into that type of bore.
If the block has not been bored yet then it should be bored with the machine shop measuring the pistons and checking the ring package to give the proper finish on the bore.
Hope this helps.
Not bored yet, it's on the machine shop, now it's depending on which
rings come with the piston set since i plan to buy a ready to go set.
i remember for my L98 i had to tell the machinist the tolerance
and give him an exact number maybe provided by some of you here
back in 2008, hypereutectics were closer to the bore than the old cast
pistons, so i think i will be getting Mahle or SpeedPro with the rings
that comes with it and then i will need exact specs to tell the machinist
what bore to do.
Now i need to decide for sure which pistons should i go with.
Thanks once again for your help.
Wrench Turner
IDK for sure.The listing states 1.56",but,9.4:1 with 64cc heads,which is about stock L31 compression with the 12cc dish pistons.Unless these pistons have some really large releifs,they either have a shorter pin hgt,or,their info is just incorrect.With your cam & 65cc heads you have,you want compression in the 10:1 to 10.5:1 range.
Also,don't let the reply above about cutting the decks scare you from doing so to achieve a proper quench.Most of these newer blocks need the decks cleaned up,especially around the water ports.Having the decks cut to 9.015".or,even 9.010" will not hurt anything,or,effect the strencth of the head bolt threads at all.That is BS.You're talking about .010" to .015".Not even 1/4 of a thread width,or,anymore than using a thicker gasket would effect the thread strength.You don't want to go crazy either by removing a lot,but,.010 to .015" is not gonna hurt you 1 bit.It will allow you use a good gasket & achieve a proper quench.
Discussion Starter #19
Yes sometimes they list in a generic way but the real specs
are printed on the box. i will ask today
Thanks once again
1 - 0912 AFR Heads
2 - LT4 Hotcam
to the feel of it.
issues.
Thanks in advance.
Never, ever round dish stockers. The dish occupies too much area under the squish/quench step of the head. This greatly reduces the needed affects of these functions and causes the engine to be more detonation prone than necessary. Either use a flat top or a D dish if tweeking the compression ratio is necessary. These type pistons off the maximum squish/quench function in the case of the D dish (cup) the flat top's advantage is retained by the step while the overall compression ratio is established by the selection of the dish volume which is wholly contained under the valve pocket.
1 - 20 of 95 Posts
