Here is the code info:
P1345
SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
You cam and crank sensor correlation is out of whack. The PCM needs to know EXACTLY the position of the crankshaft in relation to the camshaft in order to detect misfires and other functions. Whenever you change in a new part that can effect this relation, you need to "introduce" the new part to the PCM.
You need to have either a GM dealership perform a CASE relearn. (crankshaft angle sensor error)
What parts did you replace??
I caught the cam sensor(its in the distributer), but what fuel part did you replace?
Anytime you replace a cam , crank sensor, engine blaock, or crankshaft or PCM you need to have this CASE relearn performed. This is also known as a Crank Relearn.
The Tech. will hook up the scan tool to the OBD2 port, he will insert some of your VIN digits into the scan tool, and then follow its directions. This takes about 2 minutes to do.
Try and find a smaller garage to do this as they usually dont charge as much. Some places will do it for free, do you have a friend at a garage??
Also make sure the fuel pump is working, do you hear it run as you turn teh key to crank the engine over? Fuel pressure should be at 58-66 key on engine off.
Could be a fuel pump, or fuel pump relay that is located in the fuse panel under the hood.
Post back. I also have a 1997 Vortec 350 truck.
peace
Hog
