I'm stumped and have run this problem by a half dozen mechanics who usually give me the expensive answer. I've got a GMC 1998 Suburban K1500 5.7 with 250,000 miles. It only starts with starter fluid now and then idles fine, maybe a bit rough, but purrs right along. So I replaced the fuel pump relay and the fuel filter but that didn't help. Then I had a mechanic replace the fuel pump and that fixed the problem. Started right up, all was good and well for a few hundred miles until it reverted back to its old self, not starting without starter fluid. (He never flushed the tanks to wash out any dirt or debris, I don't recall).
As the pump was under warranty the mechanic replaced that pump and all was well again, fired right up and I was happy, for a few hundred miles when it happened once more. It's taking longer to start now even with the starter fluid.
So, my fuel pressure gauge test measured the following. Key on, key off 50 psi where it held steady (It should be 60 - 62). At an idle it ran at 52 psi. I turned it off and pressure dropped to 48 where it held solid for 10 minutes.
From what I've read, because pressure held steady at 48 psi after I turned it off the problem isn't a leaky spider fuel injector or a leaky fuel pressure regulator under the intake manifold - and a real pain to get to. Am I right? Or, can the pressure regulator be causing problems even if it does not leak? And how would I know? Is leakage the only problem that can arise with the regulator? With two brand new fuel pumps I find it unlikely that's the problem, but what else could it be? And, if it was the spider injector or pressure regulator leaking I would think it still wouldn't have started up even with those new fuel pumps. Opinions run the course. And what are the odds of two new fuel pumps being bad right out of the box?
Maybe there's a clogged fuel line? Some obstruction? One fellow told me he had the same problem with a small piece of paper towel caught in the line. Now, here's a clue. I've driven this rig thousands and thousands of miles on dusty dirt roads in the Southwest deserts and off-road in the Rockies. Is it possible that dirt or dust or gunk is in the tank that is blocking something? I know clogged fuel filters and this isn't it. In my experience the truck usually sputters and bumps along if the filter is really clogged, but not this rig. And, I had the filter changed.
Or, is there a valve of some kind in the line that might be stuck open or shut? I have no idea, but I don't want the mechanic to throw parts at it randomly, like replacing the spider injectors or the pressure regulator, expensive as that is. Any ideas? Thanks.
