I am hooking up my electric speedo, with the sensor cable adaptor, I have an adaptor between my cable and trans I am going to use to mate each other. I have a hard plastic stem that seems to go in there approx 2 inches long so the speedo can read, is this correct? Seems way to loose for me! Next que: I do have a fluid leak around my flywheel cover (bolts) and before I start tearing apart any quick suggestions on what I should look for or check-out first? Thanks, Dana Gasket seems fine but my trans pan seems pretty wet also!
