I read related links and saw broken 1-2 accumulator springs are common. Would that cause hard shifts? I assume it's like having no spring, but still not sure if a stiffer or softer spring causes hard shifts.
The trans invoice says "HS convertor" so it's not stock, but from what I read, that should make it shift softer.
This describes it well
"If you have a stock or close to stock tight converter using the stiffer springs/deleting accumulators will cause very harsh shifting even at minimum throttle angles."
I don't understand stall convertor theory - if they don't grab until 2500-3000 rpm, it seems the car would sit there until that engine speed - mine doesn't, it moves as soon as throttle is opened, and even at 1800 rpm will bang into second.
