Arp says torque their bolt to 235. GM says to torque to 59 and tighen it 125 degrees tighter. I am using a ARP bolt, so do I go by ARP specs? There might be a difference in the stretch of the two bolts.
Bob
Bob
Yes.you need to use the ARP method.
Word of warning---customer who is a racer used an ARP bolt in his LS---when he went to remove it the bolt galled in the crank and would not come out. Had to cut the head off and then remove the crank from the engine to get the hole repaired.
