I have a 28 spline axle set that I need to clean up. They have some light to moderate surface rust on them (end to end). What would you guys suggest as the best way to clean them up prior to install without damaging the splines? The case also has some light to moderate surface rust on the interior. Any suggestions with that?
I was thinking about going with some light grit sand paper and then coating everything with gear oil once I got down to bare metal but I did not want to harm the case or the splines on the axles. Any suggestions are greatly appreciated. Thanks. Brent
