1988 ford f150 xlt lariat long bed 5.0 302 auto column shifter
Any ideas for what parts to use to build a fast but street-legal 289?
As points of reference, a Hi-Po 289 was rated at 271hp, the Shelby version 306hp. SCCA Trans Am 302 Mustangs made around 500hp, but those were some pretty radical race-only engines.
I think you'd have a heck of a lot of fun just duplicating one of those 289s. I don't know if you'll ever get to "at least 450hp" even stroked. Or if a stock block can handle supercharging.
Maybe I'm way out in left field. Would be cool to hear from Ford guys here.
The T500hp Trans Am 302 engine were Cleveland engines, different animal. I ran a stock dyno tuned 306hp GT 350 engine in both my '34 Ford and '65 Ranchero and from the 1/4 mi et/mph they were over rated. Probably closer to maybe 275.As points of reference, a Hi-Po 289 was rated at 271hp, the Shelby version 306hp. SCCA Trans Am 302 Mustangs made around 500hp, but those were some pretty radical race-only engines.
haha hasent been pulled outa the good ole 65 yetwelcome back. How is the monster 289 performing?
If it is a factory roller cam block, then for sure it is smarter move than rebuild on old 289.i mean whould i be better off just building the 302 in my f150 to begin with ?
The 302 and 289 blocks are different. It has been a long time but my memory says you can't make a 302 out of a 289 without some lower cylinder clearancing for rod ends and I don't remember it being recommended.If it is a factory roller cam block, then for sure it is smarter move than rebuild on old 289.
the only real difference between 289 and 302 is crank stroke, they both share the same 4.00" bore diameter..
289 is 2.87" stroke, 302 is 3.00" stroke.....the 302 is just a "factory " 289 stroker.
(I know somebody is going to mention connecting rod length....but it really doesn't matter as far as power)
Yeah, you are right, it's another of the little particularities of the 289 block.The 302 and 289 blocks are different. It has been a long time but my memory says you can't make a 302 out of a 289 without some lower cylinder clearancing for rod ends and I don't remember it being recommended.
