2K Aerosol epoxy, filler primers AND Urethane clears!!
First I was stoaked to find this product at NACE last week, second, I am disappointed it that it isn't their there web site so I can show you "in the flesh".
I found it at one of the first booths I walked into, from the folks at Medallion Refinish systems. I actually saw this technology at a number of booths including some of the big paint companies, but only with clear.
Medallion has it in the long standing, respectable name of Rubber seal. Part number RS-586 is an iso free 2k, 2K! then RS-587 is an epoxy (also 2K of course) primer. The RS-586 has a two day pot life and the 587 as a 4 day.
So over a weekend you could do a number of projects and get them in 2K primer from an aerosol without a compressor!
And then here is the RS-588 urethane clear, IN AN AEROSOL CAN!!!! Is this great news for the home hobbiest or what!!!
You could paint some basecoat with a "Preval" sprayer and then urethane clear it, again, without a compressor!
Is that cool or what!!
This can is a special can (natch) that has a compartment inside with the hardener in it. You take a "button" off the top of the can and put it in position on the bottom and press it in to break the compartment and release the hardener.
I was told this is a REAL quality two componant, insoluable product. I specifically asked if it would pass a "thinner test" where you rub a lacquer thinner soaked rag on the cured product without softening or rubbing off the product. They said emphatically, YES.
I will be ordering some from our Winzer rep (the only guy I know where I can buy it near here) and give you a review of it as soon as I can.
Keep checking or email them and ask about updating the web site at medallionrefinish.com
Edit... I should have went thru all my fliers from NACE before I posted......How about some custom paints in a 2K aerosol can? Check out more about this paint delivery system and some VERY cool custom products here.... http://www.alsacorp.com/products/killercans/killercans_prodinfo.htm
