I have always liked the Ford Flatheads and thought I would build a Pickup with one bt wanted to keep the look but have modern internals. It has a T5 behind the 8BA flathead. There is four coils mounted to the firewall inside the cab so you may notice the plug wires running through the firewall.
It has no distributor but has a crank sensor for ignition. It is running 4 carburetors but the have had the venture's bored out and a piece of straight tubing pressed in, just using them as throttle plates. I am running 8 side load injectors under the intake manifold and hidden plus a straight shot of fuel to the back of the intake valves.
The distributor has a sensor to let the Electromotive ecu know where number 1 cylinder is for 100% full sequential injection.
