1 - 20 of 40 Posts
Premium Member
This is my '30 roadster that I wanted to build with hidden fuel injection and dual turbo's. The body is all steel and was purchased 15 + years ago by my cousins father-in-law that passed away. If it had been an original roadster I would not have rodded it. I'm 78 so give me a little l forgiveness.
613641
613642
613643
Checking to see where I wanted to cut the '32 frame rails to fit the body better.
613644
613645
613646
613647
613648
613649
613650
Premium Member
Discussion Starter #2 (Edited)
613651
613652
613653
613654
Frame is relieved for the Turbo oil drain.
613655
613656
This is my setup for machining the block for the fuel injectors, using shop vac to keep the mess down.
613657
613658
Using Phenolic block to mount the fuel rails to.
613659
Premium Member
Discussion Starter #3 (Edited)
613660
613661
613662
613663
613664
613665
613666
613667
The fuel rails are from a 1980 Nissan Maxima V6 which have the side load injectors as you can see it is a tight fit. The fuel rails are cut and fitted to the Phenolic bl
Premium Member
Discussion Starter #4 (Edited)
613670
Matching up the intake ports for the 4 x 2 intake.
613671
After I had machined the fuel injector holes I cut up an old cracked flathead block to see what I was
messing with. I wasn't aware or the coolant passages around the ports and you can see I missed them but don't know how.
613672
Cleaned the block good.
613673
613674
A smooth surface for the o-rings to seal.
613675
Opening for the injector wires,
613676
613677
Drilling hole for oil line to filters.
613678
613679
The bottom pipe is the oil supply to two oil filters, the next fitting up is oil from the filters to the engine. The oil hole under this fitting is plugged and the oil has to go through the filters, the brass tee diverts oil to the turbos and the top is for pressure gauge.
Looking Good.
You can put all of these threads together, and just keep adding to it. This way will be easier for everybody, and you to keep up with.
You have a nice looking place to work also!
Premium Member
Discussion Starter #6 (Edited)
613680
The carburetors has the ventures bored out and a straight piece of tubing pressed in, using the carburetors for the look and using them as throttle plates.
613681
613682
613683
613684
613685
613686
The dual turbos are from a low mileage 2014 Ford F150 Ecoboost.
613687
613688
613689
The threaded holes in chock shaft is for the hold downs for the carburetor bonnet.
Premium Member
Discussion Starter #7 (Edited)
613690
613691
Here you can see the hold down screws with holes in them to tighten them and then a clip through the holes so the won't loosen and the engine swallows one.
613692
613693
Showing the line sticking up that connects to the fuel rails under the intake. on the other end of the engine is a fuel return line to a regulator then to a fuel cooler before returns to the gas tank.
613694
613695
613696
The two boxes by the radiator shell are water to air intercoolers.
613697
613698
613699
Premium Member
Discussion Starter #8 (Edited)
613708
Using the old gas fill hole to fill the remote master cylinder reservoir.
613709
613710
Showing the four coils and ecu.
613711
613713
613715
Showing the crank trigger for ignition.
613716
1964 Thunderbird, 390 4 bbl.
I have to ask. How much boost, and roughly how many horsies is that flathead making? :cool:
Wholly smokes! That right there is some bad ass engineering! You must carry your balls around in a wheel barrel drilling holes in blocks with hand tools and stuff.
Incredible! I am amazed at the detail. Thanks for sharing.
Premium Member
Discussion Starter #18
Thank you 19Sonoma, appreciate your comments but I only showed what worked lol.
Incredibly cool build! I wish there was a way I could get this to Gene Winfield, he's a flattie lover. Thanks for all the great info and pictures.
Premium Member
Discussion Starter #20
I live about 25 miles from his shop. When this Covid is behind us I could drive over to his shop. Thank you for the kind words.
1 - 20 of 40 Posts
