Hey
i have a smog 77 sbc (010 block 4 bolt main ,for now its stock internally, quadrajet 4 barrel carb, 882 heads.
I took off the smog pump and the accessories then replaced the exhaust manifolds with midlength headers to a y pipe the duals after
All trans rebuilt th350 ,i dont have any specs on it so im gonna assume its near oem
So right now im looking to get to in the neighborhood of 300 hp from 170 it came rated at
I currently have but not installed a 1406 edelbrock cfm carb and a ZZ4 chevy performance aluminum intake .
Id like to figure out which way to go n a mild set of heads and a decent cam ,i dont need anything special .
Ive also been told i can “wake the car up “ with some adjusting the timing of the cam? Is that true or bs?
Thanks for your time
