Picky picky picky lolPower transistor? for what?
Ignition? Injector resistor?
Maybe you could provide more info?
Do you have spark? fuel pressure? Injector pulse?
Fuel Pump comes on- No spark at the coil packs . The power transistor tells the coils when to fire. That was a common problem on these cars. Replaced that , and still no spark... Cam shaft Sensor is next in the circuit. Would that cause the same symptoms?Power transistor? for what?
