1 - 2 of 2 Posts
I have a stock 55 Chevy 3100 Apache I will be installing a 302 V8 and a Turbo 350 transmission. It has the stock engine mounts, can someone help me identify the correct engine mounts, mounting spot on the frame and can I use the stock transmission cross member?
When a sbc was installed in a 55 it used front mounts like these.
Pics here on how they get installed.
With a turbo 350 you need to remove the stock bellhousing crossmember and use a rear trans mount. One from a 73-87 Chevy truck will work.
You can also buy kits to side mount your motor.
Like this.
1 - 2 of 2 Posts
