what power?
Your engine was rated at 210 HP at the rear wheels, and you can easily make a 275-300 HP engine out of it,with just mild modifications.
Being you are dropping this engine into a heavy vehicle, I would concentrate on improving the lower and mid range power, and not so much on the peak HP, which when you make the necessary mods to improve the lower end power, the upper end will take care of itself.
After that its a matter of how much you want to put into it.
Cubic Dollars = Linier Horsepower; how fast do you want to go?
BTW, there are a lot of 302's out there on the street putting out 400-500 hp. A supercharger does wonders to an engine, even running the stock cam. With your stock compression and running 6-8 lb of boost, you could pick up 150 hp, and your lower end figures would go through the roof as well.
