Premium Member
A 351 windsor will pretty much bolt in anything that had a 302 with minimal hassle.. Given a choice installed in just about anything I'd take the 351.
Later, mikey
351 Windsors have different deck heights. They are all taller than a 302.
Mike is correct; it is easy to bolt in a 351 where a 302/5.0 came stock. The 351 uses a wider intake and taller distributor. The issues come in with the height and width; hood clearance is often a problem. The EFI intakes are very tall; often a carb conversion allows you to squeeze the 351 under the hood. Motor mounts can be swapped or modified to address the height issue. Width can be an issue too.
The 351 is way better all around. It has bigger crank journals, longer rods, and of course the extra displacement is better too. :) I have heard of them being stroked to 427 cubes. :D
