I recently scored a 305 chevy, from a mid-eighties boat (the guy said it came from either a Caprice or a Catalina). We've tore the motor down to clean it up, and it's cleaned up pretty nice.
It has an aluminum intake for a four-barrel, although we don't have the carb, and it doesn't have the distributor. The exhaust manifolds I think we'll just toss, since they have the stupid AIR ports on them, but everything else looks to be in real good shape. The guy we got it from yanked it from the car because the car was about totalled, but it ran great, and he said he just didn't want the perfectly good motor to go the junkyard and rot.
So, what can be done to make this engine rock? I'm thinking of using it to replace the tired 305 in my truck, but I don't know exactly what I can (and should) do to make this engine have some more pep.
The pistons look pretty darn good, and the rings seem to seal pretty decent. All of the rods are tight, so we were thinking maybe we shouldn't mess with the bottom end. It was a low mileage motor, something like 60 or 70K, we only tore it down because it had been sitting out of the car for a while and we wanted to get all the sludgy oil crap out of it.
We don't really have a lot of money to spend, but we would like to get some solid torque of it for my truck. My truck has a 4-speed stick, and it will have something like a 2.93 rearend, so I'm looking for some more low-end grunt.
I wouldn't mind getting an intake and a set of headers, the only worry is I don't know if I can score a nice carb on the cheap, and my truck is currently TBI. I also don't know if I should plan on using the TBI set up. I could get a set of Vortec heads for this 305 from another 87 truck, and the intake and TBI system. However, I would much prefer to get a carb on it.
I've been told that getting an adapter plate to put my TBI on a nice edelbrock intake should make some nice power.
And please, nobody tell me to just get a 350, unless you have one you want to give me or somewhere I can get one for 20 or 30 bucks that's in pretty good shape.
Ooh, one more thing. I've always wanted to offset grind the crank on a motor. Are there some stock con rods that could be used for this idea, or is this going to be something totally not worth the effort and money? If this would be doable, I could have a nice stroker that should make a lot of torque.
Or should I look towards boring? Can these motors be bored enough to take 325, 307, or 327 pistons?
Can these engines be bored out enough to make it worth the effort? I have been told by some people that these 305's have the same block as a 350, just not bored out as much, but others have told me the waterjackets are thinner, and that boring it out that much can leave the cylinder walls to thin. Is this true?
Any constructive ideas would be appreciated.
