1 - 18 of 18 Posts
307 is just a sbc same as the rest. If 1 horse per cubic inch is ok with you,then how many cubic inches does your car require?
the original 307 from GM came with cheap parts that made them less reliable,,example the first nylon cam gear I saw was on a 307 and it was worn out to the point of failure.
It might go in my 81 c10 when the 305 goes out but for now just build it back up and leave it on a stand till time comes to drop it in but I want it go faster then it did before a bolt ate the piston out and had to do a motor swap in my 72 c10
So your saying the engine swallowed a bolt and wiped a piston out in the 307? If that's the case then it'll need a rebuild as you know and the problem with these engines are you can't get a set of decent pistons for it. The only pistons you can get without spending a ton of money is the "rebuilder" pistons, these pistons have .020 knocked off the compression height which kills compression and quench. The only way to get decent compression and quench with them is to have the block decked to zero. Now, if the engine was reusing the factory pistons and you want basic street performance with nothing wild then slap a set of 416 casting heads off a 305 on it, add a Summit 1102 camshaft, double roller timing set, small tube headers with dual exhaust and a aluminum intake it'll give it great torque and good fuel economy with good performance. The 307 is pretty much a ugly duckling of the sbc family. It was created when GM engineers realized they needed a small cubic inch small block that would go in there economy cars. When the 283 was dropped from production, the 307 replaced it. All they did was take a 283 block and throw the crank from the 327 in it. These engines were never popular for 2 reasons. The first is there was never a performance version of it made. It came only with a 2 barrel carb, dirt low compression, small valve heads and a single exhaust system. The next problem is in the late 60's the cam used in the 307's was the 300 horsepower 327 cam and GM had a bad run on these which caused them to go flat quickly and usually wipe out the rest of the engine with it. That's not to say you can't get performance out of these engines as you can, however If your 307 needs a build and new pistons I wouldn't bother investing the money as it would be cheaper to build a 350 which is 43 cubic inches bigger. You could throw the 307 crank in a 350 block and you'd have a 327 which is what I'd do, but that's just me.
307
My opinion...scrap the 307 block and get a 350 block. Keep the heads from the 307 and bolt them on the 350 block. I believe they had smaller combustion chambers and would increase compression ratio on a stock 350. I've never been impressed with the 307 and have never really seen one that produced any decent amount of power. If your goal is 1 hp per C.I. (cubic inch) then 307 hp versus 350 hp is substantial. But, its only my opinion.
307 build
Dang it..." DoubleVision" just gave you the long version of what I was trying to say. He must type way faster! LOL ! But he's dead on. The internal components for a 307 are limited and the quality of them is questionable as well. Just aren't any performance parts that I've seen for a 307. By the time you do any machine work to a 307 to get you any performance you've already spent a fortune to create limited HP that would be easily obtainable by bolting in say a 350 Vortec with low miles. Slap a good intake, carb and headers on a Vortec and you've got a pretty reliable and peppy engine.
307
cant seem to get a pic to post...have a pic of it under my profile. Keeps telling me its too big. Also have a you tube video of it : GMC S-15 BUILT 383 STROKER
Yes, all caps. Step-son posted it for me because I suck at doing things on the computer.:smash:
307
I dont argue the fact that money buys speed...but I'm certain that most mustang and camaro owners have far more money wrapped up in their rides then I have wrapped up in mine. I just appreciate a street sleeper that is unassuming. I also appreciate all forms of muscle cars, hot rods and customs. I have a great love for mustangs and camaros...but people expect them to be fast and perform.
I'm as proud of what I've built as anyone is of something they built. Putting your time, heart and soul into building a ride is what brings satisfaction...anyone can put money into a car.
re size your digital pictures before posting them. Use Irfanview. its a free download.
50MB to 75 MB JPG file size and 640x480 resolution is plenty big.
The raw file size and picture resolution that your digital camera produces is way too big for internet posting.
IrfanView - Official Homepage - one of the most popular viewers worldwide
Thanks F-bird'88. I'll give it a try. Building a 10 second car is easy compared to posting pics on the internet...LOL...well, for me anyway, not real computer savvy
Snakebit68, I agree with F-Bird'88 on Irfanview. I use it constantly for photo editing. It's a free program and it works GREAT.
I have a couple of Irfanview instructional PDF files that I made up for the Yahoo Group "Sharpfans". I also have them posted at Keepandshare.com, you can view and download from there, or I can email them to anybody who would like to have them.
The first file, Irfanview - Getting Started, shows how to use Irfanview to resize your photos and several other options like adding text captions to your photos and cropping your photos.
The second file, Irfanview - Panoramas and Screenshots, shows how to make a panorama (merge multiple photos into 1 big photo) and how to do screenshots of your computer monitor using Irfanview.
Hope this will help get you "up to speed" on working with your photos. It's really pretty easy once you've done it a few times.
Ed
307
Thanks guys. I'm checking it out now. I just learned how to use the dang camera...now I have to learn how to fix the pics I took. Ahhhhh...can you even buy film anymore? LOL. I'll play around with this program a bit and see if I cant post a couple of pics of my truck on here. It's nothing spectacular, but its mine!
Discussion Starter · #16 ·
Well the 307 had a **** ton of pulling power when I had it in the truck and when my dad had it back 20 years ago wouldnt bog out or nothing and tbh I dont think ppl give 307s credit cause mine a bunch of torque and im wanting power to much it without boring it and I got a 350 4 bolt main in my 72 c10 now
X2 - anyone can buy it, but not everyone can build it. And there is nothing to be embarrassed about by making a mistake or two and living and learning. I find tons of satisfaction in building stuff from low budget/stock parts and putting my all, which isn't much, into it. I'm glad to see others do as well. :thumbup::thumbup:
do things cheap
some people cut to many corners and buy poor quality parts.
I think hot rodding and do it yourself is more effective when time and effort are spent on quality care of assembly.Those "free" horse power are hard to comeby but its your time.
Lots of quality and inexpensive factory parts can be reused to make a strong 307. the 307 is just a stroker 283,,, for horse power you have more potential than using a 305 because of the bore.
for a daily driver truck I might choose the 305 over the 307...
1 - 18 of 18 Posts
