Although I wouldn't trade my 327 small journal crank for a 283 small journal crank, hey, whatever floats your boat.
Just playin' around here.....
4.030" 327 block.
3.000" 283 crank.
6.000" rods.
Forged pistons with 0.100" solid dome. What we're looking for here is the smallest dome we can use that will get the crown value to close to zero, neither negative nor positive, so we can make a 10.0:1 static compression ratio motor using 60cc heads. We want to use 1/16th inch or thinner rings to minimize flutter at high rpm's.
L31 Vortec heads, 062 or 906. Cut 0.028" off the heads to arrive at 60cc chambers.
High-rise single plane intake. You wouldn't believe how long it took to find a single plane intake that fits Vortec heads, but here it is....Amazingly, I cannot find a comparable single plane Vortec at Edelbrock or Weiand....
Professional Products Hurricane+Plus Vortec, satin part #52033, polished part #52032
750cfm carb of your choice.
10.0:1 static compression ratio.
1 5/8", long-tube, equal-length headers. I ran this DynoSim through open headers, because this sounds like a race application rather than a street application. Through the mufflers takes away 30 hp on the DynoSim.
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=236&sb=0
RPM HP TQ
3000 185 323
3500 240 361
4000 301 395
4500 360 421
5000 410 431
5500 449 429
6000 479 419
6500 499 403
7000 506 379
7500 506 355
8000 489 321
Volumetric efficiency 101.8% @5500
BMEP 212.2 @5000
This motor makes a beautiful wide and flat horsepower curve on the DynoSim graph. I wish I could find a way to show you, but can't figure out how.
I've run DynoSims on these small motors before with Vortec heads. They really seem to like 'em. This is using the published figures for flow. If you were to do a little bowl work, there might be more to be had.
On another thread, F-BIRD'88 suggested that the information given by David Vizard on his site concerning head flow and how to improve it should be required reading by all us knotheads. I agree.
