got a 327 with2hump heads for 250 dollars! goin in the nova. it came out of a 68 camaro, and is either a 210 or 275 horse motor. never bored. comes with origonal intake. i am considering putting the 350 horse cam in it, what do yall think
double humps
If you are running a standard trans. you will be okay with the 350 hp and the saturday night special idle quality , with automatic you need a stall converter due to the low vacuum it will carry approx. 10 inches.The 350 hp cam only makes a small amount more hp then the 300 in real dyno numbers.20-25 hp more but the torque is almost identical .I have dynoed both and I would go with the 300 hp .
Discussion Starter #3
so i should go with the 300 horse cam huh? will this have any sound to it? what about idle? keep in mind im going with a th350 with a full manual valve body.373 gears also. running super40 series flowmasters as well turned down after the front seat.
350 hp cam
You will like the sound of the 350 hp and you have the gears and trans too make it work, enjoy ! Sounds like a fun ride .I want a ride .
your motor is a 275hp version since it has the camel hump heads. THe 275hp and 300hp motors use the same cam if I remember right. the 350hp cam will work fine but it`s a little out dated. Check out Lunati`s Voodoo series cams. the 262 or even the 268 voodoo would be a great cam for your motor.
