Before I answer anymore questions,do your plan to drop a stock motor in,like from a bone yard,or do you plan to go threw it,if you plan to go threw it,what are you really after,think hard about that. Will this be your daily driver? And if it is,is this something you expect to run hard? What do you consider hard? Do you think power is more important than gas mileage,and is high speed the priority,or is 1/8 mile or 1/4 mile times most important to you? To design a ride you need to know these things and if your like the majority of us,something will have to be compromised due to funds,this most certainly means redesigning other things to make the compromise work,for starters,what gears and trans do you have,do you just want a low dollar v8 rig? I think lonestar makes a valid point,you are light in the rear and spinning the tires will be a problem,with most v8s,even full size trucks,it can be a chore to hook up,either deal with it,or do things like tubs with big tires,a narrowed rear end,4 link,or whatever you can think of to suit your needs,if thats a priority to you,some people love to be able to twist em up good to show off and just put on good shocks and traction bars.
