Several of yuze guys have been asking about how my car is coming. Time has been in short supply lately, but I have been dedicating just about every waking free moment to it. The car has been completely disassembled for the last time. The body is off the frame and on a rolling fixture. I am hoping to paint either late September or early October when it cools off a bit. I have devoted a huge amount of time in getting the deck lid to fit correctly with even gaps. The body where the deck lid meets had also been consuming a huge amount of time. The glass work in the channels was very course and needed to be smoothed out first. I then layed on a good layer of Evercoat Rage and sanded most of it off to arrive at some nice looking deck lid channels.
The pics show the first application of Evercoat MX241 polyester primer around the deck lid opening and the front cowl area. The cowl area also required a large amount of work to smooth it up. There were portions that had very rough glass work with some divots and other defects that had to be corrected. The first coat of primer really shows up the things you don't really notice when you are roughing up the raw glass. It will reveal lots of pinholes that will be filled before the second coat goes on.
All the voids that existed around the front windshield opening have been repaired and it looks good.
I am next turning my attention to the door openings that also have some rough glass work to be corrected and filled. After the above items have been taken care of I will apply several heavy coats of MX241 to the entire body. It will then be block sanded again and a coat of PPG K36 2K primer/surfacer will be applied followed by another block sanding session. I have just about removed my fingerprints with all the sanding that has been going on
ain: . Following that a final coat of PPG K36 will be applied and wet sanded with 600 to hopefully arrive at a ready for paint body.
The fenders, running boards, gas tank cover have all been primed and block sanded once.
