I've need your opinion about the older version of the #993 heads, I have a set on an engine and i am not looking for a drag race engine, i would be very happy with 300 horsepower, are the heads capable of producing that amount of power.
Here's another question I am swapping camshaft's in my 9:1 comp 350, that has these #993 heads on it, the engine has Edelbrock Torker intake manifold and headers, the camshaft that's going in is the Crane Powermax 272/284, the ignition is GM Hei with 50.000 volt coil.
What do you think would be the best initial timing for this engine and also at full advance (and at what rpm) The carb is Holley HP 750 CFM, what jet's should i put in it, so it won't run as rich as hell !!!
Best regards.
Best regards.
