I Moved This Post From "Introduce Yourself", I read somehwhere it said to ask your first question there, but I was told I should move it here so here goes:
I have a 1972 Chevy Nova (Fake SS) with a 350cid, with a Elelbrock Performer 600cmf 4BB carb. I think it has a mild performance cam. And no one who has tried has been able to time it right. I looked all over this site, both searching and looking in the knowledge base, but I couldnt find any information to help me. So I thought I would ask if any one has any helpful ideas.
A few days ago, the initial timing was at 27* (i think) and i dont know if it was before or after TDC. and it was running pretty good. Then one of my buddies in shop class tuned my carb, later that day my dads friend decided to play with everythign in the engine, and found that my distributor had NO springs it it, so he put some in, and we have had even more trouble timing it after that. Last night my buddy set the timing to around 17*. and adjusted my carourator to get my engine working well enough, but it kept killing when I put it in gear, but I had to go somewhere so we just upped the idle speed, so i could leave. So i have no idea what to do right now, I dont know that much about engines, and i would like some help on what I should do in attempt to get it timed right. Please Help!!! almost anything would be helpful!
I was told that maybe my ballancer is off because the rubber in it gets old and it spins out of whack, but i dont know if that is the case. and I think i read somewhere that if i have a cam the timing tab is useless. How much of that is true? Is it possible that my distributor was put in wrong?
OH! Also, its a pain in the butt to start.
Thanks!
Thanks!
I went out to work on it today with one of my buddies. We brought the timing down to 10* advanced. or around there. but it would kill when we put it in gear. But it didn't wind down, it just shut off, as if someone tunred the key off. so we adjusted the idle mixture the way the manual for my Edelbrock carb said we should. Then we upped the idle speed because the engine kept dying. But, after we did that, it popped a bunch when i would get on the accelerator hard out on the road. So i brought it back, shut it off and it deisled for about 15 second and it wouldnt stop so i turned the key forward and back really quick and it stopped. We brought the timing back about 4* so it was around 6* advanced, and it still deisles really badly, and has very little umph, but we couldnt fix it cuz my mom called and told me to get home right away. Any sugestions?Better to post this question in the engine forum Dude. It does sound like you have a balancer problem to begin with as it should not wobble so find another and change it over and then try you timing and carb adjustments.
