1 - 8 of 8 Posts
My friend has a 350 in a 51 Chevy that has multiport FI that he says was on a Corvette. I'm trying to order a wiring harness and apparently there are 2 different ones depending on the year of the injection system. How can I tell what year it is? I've looked for a number on the thing and not sure where to look. It ahs been running before and just quit. Whoever installed his wiring harness was a butcher and he has no power in one section of the fuse panel. I think replacing the harness and doing a clean install would be easier that patching it. Looks like a fire hazard on a $120,000 car
When you say multi-point is the intake and injectors on it GM?
If these are then are the injectors one per port external on the manifold (TPI) or grouped in a pod inside the intake with fuel runners to a simple check valve at each port (MPFI).
Obviously the Holley computer tells us this is either a Holley system, or somebody used a Holley computer on some other system.
1 - 8 of 8 Posts
