This summer I bought a 71 Chevelle with what is supposed to be a 350 lt1 motor. The numbers on the block and heads seem to support this. I drove it 150 miles home and drove it for several weeks. It had a clutch problem when I bought it. It was bending the frame bracket every time you pushed in the clutch. It was not a heavy pressure plate, it had some problem. Changing the bracket and clutch,pressure plate and throw out bearing fixed that problem. Then it started to miss. Just a little at first then got worse. Now it is dead on cylinders 1 and 5. I tried swapping plug wires with a known good one but it stays on 1 and 5. I next tried new plugs. Still there I had another Holly carb so I tried that since it seemed like they were rich. No difference. I then set the points (it has a mallory comp 9000 dual point dist). I wanted to get rid of that so I ordered a HEI dist. On trying to install I found that it wont clear the intake. It has a edelbrock c4b manifold. So a new manifold is in the works this winter. I set the timing and it seems to backfire in the intake sometimes with hesitation. I ran a compression check and all cylinders are between 169 and 175lbs. I can touch the headers and the 1 and 5 are just warm where as any other cylinder is hot. You can also tell the exhaust is hot out the right bank and barely warm out the left. I tried moving the plug wires in the dist one plug wire over and turning the dist to make up the difference just in case there was a bad dist cam. The plugs all spark real good. I finally timed it by ear. Turning the dist reving the motor to get the least hesitation. It pulls hard all the way to 6500rpm but still has 2 dead cylinders. The popping in the intake rarely happens now. I ordered a dial and magnetic base and my next step is to measure the cam. Thats what I think is wrong. 2 cam lobes worn off. I installed a anti power valve blowout kit in the carb and put in a new power valve to. The only other symptom is the vacuum reading. At idle it varies from 10 to 14 real fast. As the rpms come up it steadies and rises to 21 or higher. I think if the cam lobes are bad I will pull the heads and make sure they have the hardened exhaust seats for unleaded fuel. And have a valve job done. Then it will be new cam,lifters,springs,retainers,locks, and timing chain and gears. Any other thoughts would be welcomed.
Gary
Gary
