I'm building a 350 for my 86 chevy pickup and just have a couple questions on the cam install. I found a cam kit on Jegs (http://www.jegs.com/i/Comp-Cams/249/K12-239-3/10002/-1#) that is designed to produce high torque. this truck will be primarily a street vehicle, but would be used offroad in situations like hunting, and the occasional "hey theres a big pit of mud! lets see if we can make it through!" situation. The specs of the cam kit are as follows:
Excellent response, good mid-range, noticeable idle.
Operating Range: 1300-5600 RPM
Duration Advertised: 262° Intake / 270° Exhaust
Duration @ .050'' Lift: 218° Intake / 226° Exhaust
Valve Lift w/1.5 Rockers: .462'' Intake / .480'' Exhaust
Lobe Separation Angle: 111°
This kit comes with Camshaft, Lifters, Timing Chain & Gears, Valve Springs, Spring Retainers, Spring Locks. I need to know if there is anything else I would need to change in the engine to match this new cam setup? What about gears? A friend told me I would need lower gears for this cam. Any ideas?
Thanks!
Thanks!
