Hello, new here and need some advice as I am clearly not an expert with engines. I am building a 350sbc for my 1951 Chevy Sport Coupe and need a little advice before I drop down a stack of money. This car will be a weekend cruiser with A/C, power steering, and power disc brakes front and rear. This engine must run on pump gas and not overheat in traffic.
Block: 350 sbc OE roller - 4 bolt main.
Heads: AFR 23 degree 195cc Street Heads
Compression: Would like to stay down around 9:1 (if possible? I hear less compression creates less heat? It gets hot in FL.
Cam: Not yet purchased
Intake: AFR single plane air gap intake (match port to Street heads, I hear single plane plays better with EFI)
Headers: 1-5/8 mid-tube headers
Fuel: Not yet purchased (I am buying Holley Sniper EFI or FiTech EFI)
Transmission: 2004R
Torque Converter: Not yet purchased
R&P: 4.30
Wheel Height: 26in tall
Car weight: 3500lbs approx
So what cam and torque converter would you recommend with this setup? I was thinking about an XR264HR or maybe an XR270HR? But I am not sure about the vacuum and the power brakes situation? Any idea if these cams will still allow for power brakes? Does anything in this setup look horrendous? Should I change anything?
Thanks in advance for any advice you can spare.
Transmission: 2004R
R&P: 4.30
