Ok here’s tonight’s question.
350 +.060, flat tops, dart aluminum heads, stock GM intake and sniper EFI. Cam is summit 1102. Fresh rebuild with about 700 to 1000 miles on it.
This thing has been burning oil like mad, like a quart every 100 miles.
Today I pulled motor to find problem. I took intake off and the egr/cross over pocket was full of fuel/oil. Now the EGR is not used and I covered the head to intake ports with the fel pro gasket(black with blue bead). The cylinder head runners look clean, Now the egr pocket on the heads was full as well, even though the gasket between head and intake had not cracked or showed no hole in it on either head. 6 of 8 cylinders had heavy oil goo on pistons, not full hard carbon yet, wipes off easily. Now the only place with oil/fuel mix is intake and EGR pockets on heads, oil under intake, valve covers and pan is pure oil. It is very black like heavy combustion blow by, oil only had about 250 miles on it.
Cylinders look ok no marks from bad rings, engine looks clean in bottom end.
Anyone seen this before, bad rings? Crack in intake manifold? Crack in exhaust area on head? View attachment 613802 View attachment 613803 View attachment 613803 View attachment 613804 View attachment 613806
