Before I start rambling..
Rebuild specs:
350 4 bolt main bored .030 over
10:1 CR
Stock Cast Crank turned .010
SCAT Forged 5.7" I-beam Rods
Sealed Power Flat Top Pistons w/ 4 valve reliefs
Vortec 906 Iron Heads
.016 Steel Shim Head Gaskets
Jones Cam's Hydraulic Flat Tappet: 110LSA 224/232 @ .050, .501"/.504" with 1.52 rockers
Cloyes Heavy Duty Double Roller Timing Set (set to advanced keyway while degreeing cam)
Melling 10552 HV Oil Pump
Holley 4160 600cfm Vac. Secondary Carb
Edelbrock Performer RPM Vortec Intake
Stock GM HEI Distributor
NGK TR55 Plugs
Factory replacement Taylor wires
High Torque Mini Starter
Rotating assembly was balanced during rebuild
Well fellas, I'm currently stumped. I just recently rebuilt my 350, and broke it in a few days ago.. used PennGrade break in oil. Break in went pretty well.. I set distributor in at 14* before starting it. It started right up, bounced around a little for a few seconds, then smoothed out as I raised the RPM's. I varied the engine speed between 2000-2500 for 20 minutes. After 20 minutes, I started to back the engine speed down. I eventually got to the point where I could no longer unscrew my curb idle screw any further. I snapped the throttle a few times, but it didn't come down. I pushed the throttle lever forward a little to make sure it wasn't the cable, when suddenly the idle dropped, I heard a clack, and it shut off. I started it again, heard clacking, and shut it right off. After removing the valve covers, I found that my #3, 5, and 6 intake rockers were loose. They weren't making a single sound until I pushed the throttle blade forward and the car died. I started turning the engine over by hand to readjust these valves.
I turned the engine over by hand while watching the corresponding cylinder's exhaust valve. Once the exhaust valve started to open, I adjusted the intake valve, and gave it 1/2 turn past zero lash. I did this for all 3 that loosened up. Then, like a complete idiot, I forgot to take the breaker bar and socket off of the crank pulley, and blipped the ignition. I heard the breaker bar rotate clockwise, hit my frame rail, and then fall to the ground. I went and double checked that the crank bolt didn't loosen up, shook my head at myself and then started the car up. It was running terribly. The engine was bouncing and running very rough, and it wouldn't stay running unless I held the throttle open. The second I let go, it would die. Now I noticed that while cranking, it was "galloping" rather than a steady crank. You could hear it crank fast, then slow, fast, then slow. Before adjusting the timing, I marked the distributor cap location so I could go back to my starting point. I tried advancing it further - didn't help. Tried retarding it a bit, didn't help. Eventually I got it to where it would at least stay running well enough that I could pull it in the garage. Out of curiosity, I checked where the timing was at this point, and it was somewhere near the 30's at idle with the vacuum advance plugged! I retarded the timing, and it shut off. Lined up with my original reference mark on the distributor cap, it wouldn't stay running again. Before taking a break, I pulled my plugs - they were black, sooty and fouled. Smelled like gas.
Today I went back to the garage and swapped another working carb onto the engine. I installed brand new plugs, and relashed every single valve. I jiggled the pushrod up and down until I felt zero play, and this time, I gave them each 1/4 turn. Rotated the engine until I saw the exhaust valve open, and fully close - right on TDC on my timing tape. Rotated it one more revolution to TDC. Adjusted my distributor to line the #1 terminal up with the rotor, as close as I could get it. Turned the key, it fired up and died. Held the throttle open a little, turned the key again, and it's struggling to start. Keeps firing off but dying. I tried adjusting the timing a little, but once again it didn't help much. Try giving it more throttle, backfires out the carb. It still has that "gallop" present while cranking. I checked my plug wires numerous times, and aside from them currently being a little messy and strung about, they are in the right positions. Verified that I have 12.4 volts at the ignition wire at the distributor, and 10.4 volts while cranking. I removed the distributor cap, and it was spotless inside. No signs of arcing. I couldn't find any noticeable rips or tears in my wires either. I cranked it again with the ignition disabled, and it sounded exactly the same.
I am completely stumped at this point. I keep asking myself if I wiped the cam, but it made it entirely through break in with zero issues, and no valve noise until the RPM's dropped and it died out. I was hoping my initial valve adjustment wasn't consistent, and maybe those few were just a little loose. But why didn't they make any noise until the engine died out when I closed the carb? The other thing I'm wondering is.. when I hit the ingition with the breaker bar still on the crank bolt, did it hit the frame and jump timing? The bolt didn't loosen, so either it fell right off, or something else had to give. I double checked my timing chain slack, and it only moves 2 degrees before turning the rotor if I turn it counter clockwise.
At this point, the only things I haven't really checked are my ignition coil, ignition module, and my timing set. I've also yet to drain the oil to check for metal particles. Either way, it sounds like the valve event timing and ignition timing is not occurring when it should, or something happened with my compression. I'm not sure, this is my 3rd engine rebuild and I am stumped and defeated at this point. Any help would be greatly appreciated, and if you read ALL of that, thank you - lol!
Here are 2 videos. The first shows what it currently sounds like while cranking, and the second is after 20 minutes of break in when I started to back the idle down. You can hear that it's running nice and smooth during this time.
Cam card:
Any guidance is much appreciated. Thank you
