I have a 1997 Chevy 1500 350 vortec. I want to swap the original cam with a better one without doing any engine work. I have a 350 that I spun a rod bearing so I ordered a short block. I am using the original heads, what cam can I use? I believe I can use an lt1 cam but I don't remember which years worked.
when the sort block arrives,measure the deck height and see what pistons it has.then calculate your compression ratio
Wrench Turner
What are you wanting expecting from the cam swap?More torque for pulling?More speed to play around with?If you are using a stock replacement short block that will retain the 9.4:1 CR,there are lots of choices.The Ramjet cam #14097395 is a good choice if you don't wanna do any other mods.I would recommend a better set of springs than the OEM springs for any cam.The beehive spring is a popular choice.The Ramjet cam will give you a good flat torque curve,maybe 25HP,idle smoothly & perform very well in a stock L31 engine.The LT4 Production cam(not the LT4 Hot cam) is also a really popular swap.The Ramjet cams be found regulary as new pullouts on EBay for about $120.It really just depends on what you are wanting to accomplish with your truck.FWIW,a good tune will be the best money you can spend on it with or without a cam swap.
Wrench Turner
As Vinnie stated above.Measure how far down the bore your pistons are.This will effect your CR.If the block hasn't been decked & the engine builder used "rebuilder's pistons"that have a shorter pin hgt,you will lose some compression & detonation resistance,so,you will need to be a lil more picky with cam choices.If your pistons are more than .028 to .030 down the bore,that is prolly the case.
